Foamboard dlgs
flyboa
@bracesport started a 1m rebuild. Receiver is from a Whipit and will be rudder/elevator. Wing build is much faster than the 1.5m.
flyboa
Not really. It is a 2ch so I do have to fly it differently than my 3ch planes. It will loose altitude in a turn if I slow down too much.
bracesport
@flyboa - you are the master of the air and you have proved that lighter weight really does pay a dividend (is your foam wing 1300mm)? - I think on my last build the fuse was too short - what is your typical measurement between the main wing TE and the LE of the horizontal stabiliser for you 1.5m ships?
flyboa
I usually try 17.5". That 52" wing probably could use more dihedral. It felt too sensitive to aileron inputs with the expo setting used.
