Monte.C
I'm surprised! Wonders never cease.At Dollar Tree the black DTFB I got was black core...
Interesting. The stuff I've bought is definitely just black paper on white foam.At Dollar Tree the black DTFB I got was black core...
And we don't state the sheet size on the label because 'Murica. Or because we're ashamed of our units?Interesting. The stuff I've bought is definitely just black paper on white foam.
Hmmmm... That looks identical to what I got just my foam was black not white.... have you looked more recently?Interesting. The stuff I've bought is definitely just black paper on white foam.
If is all black Im gonna load up on it. Ill go to the boujie dollar tree at lunch tomorrow. Theyre always fully stocked.Hmmmm... That looks identical to what I got just my foam was black not white.... have you looked more recently?
I hope it is, mine was for sure, it also ways 10g less per sheet and felt stronger also, paper was stuck a little better.If is all black Im gonna load up on it. Ill go to the boujie dollar tree at lunch tomorrow. Theyre always fully stocked.
Oh, and maybe it can transport my wing like a 747 transports the shuttle.
To reexamine your question... I really think the answer would be yes. With a D3530 mine balances nose heavy with a 1000 MAH battery and I don't even have all of the canopy stuff or the landing gear on yet. Mine should fly straight up with this set up. It is lighter than my P40 and that plane will fly vertical with this engine. With some flaps it would be too easy.when the plans come out do you think it would fly with a 2212 1000kv motor? i feel like it would be a little underpowered.
No it would work for sureTo reexamine your question... I really think the answer would be yes. With a D3530 mine balances nose heavy with a 1000 MAH battery and I don't even have all of the canopy stuff or the landing gear on yet. Mine should fly straight up with this set up. It is lighter than my P40 and that plane will fly vertical with this engine. With some flaps it would be too easy.
In hindsight, I should have put my servos further back like yours, mine are right under the main wing. Although it will be super lightweight if I want to fly it with the 1000. All I have are 1000s and 2200s, so my plane either gets a brick or it gets a 1000 lol. Actually, I bet I can carve out some room if I really wanted to and push a 4500 back in there, but I would end up getting bored before it was time to land.I have a 2600 3s lipo in it, running a 2216 1300kv on 30% throttle
Awesome, hope that stuff works outWell this inspired me to keep searching for black foam board here in the US. Not only did I find something that looks promising, but it's shipping from Uline's warehouse only about 3 hours from my house!
https://www.uline.com/Product/Detai...ards/Foam-Core-Board-20-x-30-Black-3-16-thick
By the time I paid shipping and tax, it worked out to a little over $4 a sheet. Not as cheap as DTFB, but if it's good stuff it'll be worth it.
It is because it varies by about an inch a sheet (or 25.4mm). I've had some under 30", and some over. They sure as heck won't write thickness, that is everywhere.And we don't state the sheet size on the label because 'Murica. Or because we're ashamed of our units?
Just put up the plans for everyone, windshield parts are thereThis is where I am at, all I need is the windshield.
Ratcheroo has promised me more parts, if not, Im gonna hack it together! View attachment 219838 View attachment 219839 View attachment 219840
Flaps down for @Monte.C
It probably isn't Adam's Readi-Board if it's black foam. Their black fb has white foam. The weight may be different than Adam's fb, too.Hmmmm... That looks identical to what I got just my foam was black not white.... have you looked more recently?
Interesting….It probably isn't Adam's Readi-Board if it's black foam. Their black fb has white foam. The weight may be different than Adam's fb, too.
