Free, easy video editer for YouTube?
Vimana89
My building and flying is getting a lot better, but all I have so far on my YouTube is raw, unedited video clips. I'm a complete newb at video editing and would like a preferably free, easy, user friendly program for editing. Nothing fancy just need it to: 1.), edit and cut parts where the plane leaves the screen and stuff.2.), add text and music.3.) Compile a video from pieces of multiple different clips of footage. That's all I need out of it, in as easy and accessible a format as possible. Any recommendations?
#2
Take a look here: https://forum.flitetest.com/index.p...deo-editing-software.22405/page-2#post-473022
TexMechsRobot
#5
Try HitFilm Express. Free. Not necessarily easy but not hard either. And there are a ton of online and YouTube tutorials.
Vimana89
Thanks for all the responses! There's also another someone recommended in a private conversation ill have to dig up. I'll see what works best for me and go from there(y)
#10
Video editing is professional work. So If you want to it impressive to viewer then you should hire freelance person to do this job or you can get online tutorial to complete your task self.
#14
#19
I started video editing using lightworks software. This helps me a lot to start editing when I was beginner. It is simple and initiative interface. As you mentioned you are a newbie you can use this application with no editing knowledge. The great advantage of this tool is you can prefer video tutorial it provides you at free of cost for learning. In light works you can also edit sound clip for your video to give your video a professional touch. But make sure to use high quality recorded sound using good lapel mic. Before recording carry a mic test online and check if mi is working well to record sound for videos. Otherwise you can also edit sound clip recorded by local mic. Lightworks will help you editing video nicely and easily also you can edit sounds for your video no matters which mic you use.
Now I use Adobe Premiere Pro plan to professionally edit videos for my channel. But you do not need to invest much on this. Lightworks is nice and easy software to start as a beginner. Try as per my advise.
