Hi,
I just switched from Spektrum to FrSky on my 4 quadcopters. I do have a connectivity issue it seem, but it is pretty weird as it behave, or not behave... I spent a lot of time troubleshooting, please let me know if you have anything else then: 'it should work'! I am willing to try anything, I am sure 2 brand new Rx and that Tx are broken????
Let me give you more details:
Tx: X9D plus
Rx: R-XSR
FC Board: Naze32 Rev6
Connected with: Sbus + Telemetry.
Got: Solid Green + Solid blue LEDs. So, should be bind properly.
Got: 9 Channels of Telemetry on my Tx. So, it does communicate this way.
On Betaflight, NO Receiver inputs whatsoever.
I am connected: S port, Yellow wire on SoftSerial 2, (pins 7&8 (but 9&10th holes) on Naze32)
S Bus, White wire on UART 2 RX, (pins 4 (but 6th hole) on Naze32)
PWR & GNDs are fine
I got in Betaflight: PORT: RX = UART 2 = serial RX ON
Configuration: RX serial, Bus
Soft Serial, Telemetry ON
I tried in CLI: set subs_inversion = ON/OFF
Loaded last Firmware for both the Tx and Rx
Tried 2 different Rx (Both R-XSRs)
So no luck, still no seing the Receivers bands moving with the sticks in the Betaflight Tab.
Is there anything I should try in my settings?
See all photos below
Thanks so so much for the help!
Tx: X9D plus
Rx: R-XSR
PWR & GNDs are fine
