Hello, I am 15 and just getting into the hobby. I have built a few FT planes before, and this is a new and interesting story.
I got my tiny trainer speed build kit over the weekend. The build of the plane went fine. Receiver binding and servos all worked well. At times, when powered on, after the initial connection to the transmitter and normal ESC tones, the ESC made a noise of two beeps with increasing pitch. This happened randomly, and I could not pinpoint the cause of the beeping. After building the plane, I researched what the cause could be of this strange sound. I came across the idea of throttle calibration. I did calibrate the throttle endpoints, and that did seem to stop the beeping for the five minutes that the plane was connected to the battery. Every time that I plugged in the batteries, they were over 50% battery, so there should be no low voltage problems
Electronics that are being used:
-Lemon RX dsmx 7-channel stabilizer receiver
-Dx6i spectrum transmitter
-FT 20 amp ESC
-Powerpack A electronics
-3s 800 mAh battery
During the maiden, set up on 4 channels, everything worked well. It took a rough landing that required changing the prop. The Last two flights that day ran through the other two 3s batteries. Everything went well that day. The next day, I took it out to fly, and I noticed that the throttle seemed to be cutting out. Around a second later after reducing throttle, I could give throttle again. I couldn't tell If I had control of the airplane, as the throttle cut out when on a level flight. Soon after regaining throttle I definitely had control of the plane. That flight went well with the throttle seeming to cut out about twice. The flight ended with the voltage alarm set at 3.7V per cell notifying me to a low voltage and I had a normal landing, so I was flying with a sufficient battery.
Later that day in the evening, I was flying in a slightly smaller area and I decided to use a 2S 900 mAh battery so I would not go as fast. At this point, the connection sound is still happening randomly. Just before my 2S flight, I was throttling up to launch and the throttle cut out. After the motor cut out and stopped spinning, the same two beep beeping sound happened, and after that, the throttle was responsive again. After 5 minutes of listening for the sound, and it did not happen again, I decided to launch. About 30 seconds into the flight, I was banking and about to yank the plane to turn about 180 degrees. Before I could pull the plane out of the turn, The motor cut out and I definitely lost control of the plane. I lost control and the plane hit the ground nose-first. No damage, just a dirty prop, and dirty foam.
After this, I decided to do a range check on the plane. During the range check, A very faint single beep sounded from the ESC, a sound I had never heard before. A few seconds later, a single, louder beep was heard, again a unique and new sound. After that, the range check was competed and no abnormalities were found.
I have no idea what is happening. Any person that could give a bit of help to solve this would be greatly appreciated. I have a few speculative questions:
Is the 2S triggering the low voltage warning on the ESC that was previously used on a 3s?
Is it actually losing connection? I have perpendicular dual antennas that are supposed to prevent that.
What is the ESC saying with the connection sound after connection?
What is the ESC saying with the single beeps?
If something is wrong with the ESC programming, how do I reprogram it with the dx6i transmitter?
Is there a specific manual for this flite test ESC?
Again, any help would be greatly appreciated in getting my tiny trainer up into the air again.
-FT 20 amp ESC
-3s 800 mAh battery
