Ft alpha problem
PaulK
I went to go fly my alpha the other day and there was no foward thrust. The motor is spinning counter clockwise and the prop is on in the correct direction but whenever you run the motor you feel air blowing toward the nose. Does anyone know what the problem is?
Headbang
Numbers on the prop need to face toward the front of the plane. If this is already the case, then swap 2 wires on the motor to reverse the motor and you will be set.
  • Like
Reactions: FDS
