What’s wrong with my micro setup?
I wanted to try and make this plane Fly:
So I picked up all the needed parts, small servos, light Rx, I first had an BR1103 then bought a DYS 5g motor, 2.5 and 5x3” prop, and ultimately HK version of a Turnigy plush 6A esc’s a Racerstar one for 1-2S and and a https://www.aliexpress.com/item/Tar...lgo_pvid=5d3172b2-1a85-4c59-b784-c47d581cbc1b. In an effort to get this matched up. I was worried I’d burn out the motor, with a 2s but I figured the ESCs are rated, and a test won’t kill it. Here’s the Setup. I found a fault in the BR1103 (bare wires) but I the DYS was fine by my ispection
As you can see I have a 500mA 2S battery hooked up to a HK 6a plush ESC Turnigy clone connected to the DYS 5g motor. When started the Motor beeps and twitched, in a mater of 20S the ESC is too hot to touch. This doesn’t make me happy so I stop it and the DYS motor is for 2S and the ESC is for 2-3S. I’m not sure what’s going on. I double checked my battery was Full and Balanced. To be sure connected my RX to another working rig… it works fine. I’ve also tried both ESC’s shown. Both get crazy hot and twitch.
What’s Wrong? I don’t understand it. Please FT Community, you’re my only hope!
![FTonlyHope.JPG FTonlyHope.JPG](https://ftforumx2.s3.amazonaws.com/2017/03/146223_d363348dd8dc7296ce8ac91bf51b004e_thumb.jpg)
![Micro Dragon FPV Concept_zpsylug4qls.PNG Micro Dragon FPV Concept_zpsylug4qls.PNG](https://ftforumx2.s3.amazonaws.com/2017/03/136412_8e44548403e7cf7f4d346c02d5525bbb_thumb.jpg)
![Micro Power Train.JPG Micro Power Train.JPG](https://ftforumx2.s3.amazonaws.com/2017/03/144228_f2feaf10da58e3ab5ac0ff9d40e5094c_thumb.jpg)
