Ok, this could be a silly question but I've searched and found no answer.
I've built my first Flite Test plane, the FT Duster, and I'm not wholly certain where the battery goes.
I've seen some pics with it on the underside of the power pod, not inside it, which certainly makes sense from a 'changing the battery' perspective.
Is this correct? (exact longitudinal position dictated by CG one would assume)
Secondly, I'm a little leery of simply using Velcro strip in a location where the battery could simply drop from the open bottom! What are people doing to counter that? I'm thinking a velcro tie that goes fully *through* the power pod (I'll make a slot at each side) and then wraps around the battery.
Cheers in advance. I've been out of the hobby for too long and been 95% a glo person and not an electric person, so still loads and loads that I simply don't know that many would take for granted.
Thanks.
Thanks.
