gabe221
I pulled all the paper off the inside, added another full length spar.Then glued it all up. Then I pulled the paper off the out side, and taped it. Next I pulled all the paper off the fuselage, inside and out. Taped the out side, then glued it together. Did the tail feathers the same way.
The wingspan is 45", with flaps. Since the span is wider, and the plane is lighter, I hope the E Max 2215-15 motor will still be alright to use in it.
