Just finished my FT Flyer after my cat finally got off my lap and went out to play. It took all of an evening to build, so nothing to get too excited about. I modified it by adding ailerons, reduced the dihedral to something like one inch under each tip, I increased the size of the elevator and rudder, and I added a little hinged protection pod for the battery underneath. I used one of those $4 gold A2212/13T motors. i was going to use the yellow no name ESC that came with it, but I discovered that it couldn't handle two servos on one channel for whatever reason, so I used one of the Flitetest 20A ones. With a 10 x 4.5 propeller, it's drawing 15 amps at full throttle and giving thrust about twice the 400g weight of the plane, so I'm hoping that it'll be good at 3D stuff - that's if it flies at all.
Finally, I used some foamboard that I got from ebay before I got my box from Flitetest. this board is a bit heavier and very stiff, so not suitable for planes with bent or folded parts, but it's perfect for this one.
So far, I've built a Simple Scout, Mini Scout, Sportster, Edge 450, FT3D and the Flyer. That's in about 3 weeks. Maybe I'll have them all by the end of the year. My next one will be a scratch build out of foam board of a plane that I flew in the '80s that had exceptional flying characteristics. I have to go up in my attic to see if i still have the balsawood plans. If it works in foam, we all have something to look forward to, as I'll try and make plans/build instructions as well.
