mayan
@basslord1124 waiting to see how your flight goes
Hoooly Cow! Yes I watched the whole thing. How could I not? I kept thinking, when does this flight end? Everyone you were flying with came in and landed. Then others went up, then they came in and landed. You were just flying around, doo, de, doo, de doo. No problems in the world. Just flying my plane longer than should be possible with that airframe.Only got in a single flight this morning using a 1300 2S battery that is almost 2 years old and rarely used, (mostly stored at full charge). Sadly it turned out to be the last flight of my mini scout as it has now been stripped and gifted to a person who was visiting the field and showed a genuine interest in becoming a fixed wing flier!
As this is going to be my last challenge entry, (unofficial), i thought it should be better than before and so I claim 12 minutes 35 seconds. Video to follow as it is taking forever to process it down from many Gigs to a reasonable file size! Now sure of the seconds as I can access the edited file now that the saving and converting process is completed!
Link to video: https://drive.google.com/open?id=1Jt1FIxLg2FG8MEa3bL4U4rTDmwqOl26n
I enjoyed the challenge and learned a lot!
Have fun!
Oooh, that hurts! I was cleaning one of my motors and thought I had lost the Circlip. That would have been end of that. Thankfully upon careful brushing of my work surface with a horse tail paint brush, I found the clip and the motor was saved!Well I'm pretty bummed out. I was close to 9 minutes (thanks to new batteries) and my motor destroyed itself. I put the throttle up to get some height for glide time and the bell pulled off the rotor!! The whole front end with the prop and everything sailed off to the wild blue yonder!! Plane flipped and flopped to the ground and somewhere in 1800 acres is the bell and prop!!! I guess I need to add a step in preflight, tug on the prop and make sure the bell is attached. The shaft is still in the housing. I was on the way to busting records and I only busted my plane. WAHHH😭😢😭😢😭😢
IF you don't fall asleep!my projection is that you should easily be able to get 20 minuted from the Mini Scout without having to fill it full of batteries!
Oh my. You sound like me, you poor, poor soul!Yeah, I've got 3 builds. A 75% bloody wonder, a scratch DR 1 and a mighty mini corsair and a new light mini scout. I'm set for things to do this week.😆
Yes! It was even better in person. No she wasn't scratch-built, but that darn bird can fly! If you are a new pilot, there is a lot to be gained from using the SpeedBuild kits. They are certainly not the only way to get in the air, but my gosh! That bird could fly! I haven't even scratched the surface of what she can do. Ya'll wait until I've the skill to take throttle to 100%, cut ailerons into it and get stupid with it.I've got the video of my Third Try at the Challenge
He didn't even know he was entering the Challenge! He just wanted to fly. I gave him a broken plane and half a battery from a previous flight with the TT. What he did with that? Yea. Awesome.Here is my son's first entry.
I didn't break the plane,I had a sudden unplanned experiment in weight reduction!Oh, the folded wing destroying the MiniScout my son was flying? How do we feel about that?
There you go. THAT's how we feel about crashing! It's foamboard, and we are having fun!
It is obvious that the wings were built as a sacrificial element!I didn't break the plane,I had a sudden unplanned experiment in weight reduction!
Take that on in this challenge that’s a dare.The best thing to do with that plane was to fly FPV a foot off the ground, inverted, at full throttle! Pow!
Like a BOSS! That's not a Pow. That's a BOOM!Take that on in this challenge that’s a dare.
https://forum.flitetest.com/index.php?threads/fly-it-inverted-the-challenge.57949/
So let me update on what has happened over the past week.
So I had replaced my thrust angled power pod with a straight power pod.
My constant left bank problem was back.
@mayan ...believe it or not, the whole plane is still in decent shape. Some wrinkles on the paper but that's the extent of it. Really a tough little plane! I've kinda often felt that for any of these foamboard planes, I would just fly them until they couldn't take anymore. That point where all the extra glue is causing it not to balance like it used to or the performance is definitely impacted. Besides scuff marks add character!
@Hai-Lee ...my motor is a 2280KV, running a 5x4 prop. I actually had made an extra side thrust pod so I can try it. A few things I've wondered:
-Perhaps I am applying too much throttle...usually start it at 2/3 throttle and give it a pretty hard launch. I've been seeing from others that this plane does best flying slow.
-Maybe the area that I was in has some sort of side cross-wind thing going on.
Today I was flying a mixed up TT cause I had broken my two other wings that I had, and I don't know why or for what reason but the TT flew different, different in a good way, felt lighter@mayan ...believe it or not, the whole plane is still in decent shape. Some wrinkles on the paper but that's the extent of it. Really a tough little plane! I've kinda often felt that for any of these foamboard planes, I would just fly them until they couldn't take anymore. That point where all the extra glue is causing it not to balance like it used to or the performance is definitely impacted. Besides scuff marks add character!![]()
Others might disagree but I think this plane flys best with little to now wind espically if flying as a 3 channel.Maybe the area that I was in has some sort of side cross-wind thing going on.
