Let me share with you my first rc plane scratch build. I wanted something small to be able to fly over the garden, easy to fly as a trainer, slow flyer, but also a little bit aerobatic to have some fun later. When I saw FT Old Speedster in the air it was love at first sight, but it needed a few changes ;o)
So, my (FT) Old Sportster has
- midi size ... 70% of FT Old Speedster
- inner width adjusted to 45mm
- wing span 72cm (28in), one piece and straight, aprox 13sq dm
- length (without motor and prop) 56cm (22in)
- ailerons 30% of wing, 6cm
- elevator ... expanded area like 3D plane, U shape, reinforced
- larger cocpit (for servos and pilot
- custom swapable powerpod
- added fuselage belly for mounting batery (and also lower CG)
- a few fuselage reinforcements
Waiting for maiden. Only wind shield is still missing.
Tech spec:
Total weight 222g without batery (using 45g 2S 800mAh, planned up to 75g 2S 1300mAh)
Weight on wing area = 21g/sq dm (up to 23)
Material:
depron 7mm (a few pieces of 4mm)
skewers
2mm wire for gear, 0.8mm wire for operation rods (Osteofix)
45mm plastic/foam wheels
velcro
fiber glass tape
2,5mm plywood for firewall and 1,5mm plywood for horns
cardboard (sturdy paper), blue packing tape
Electronics:
Emax CF2805/2840kv
prop APC 7x4SF
ESC Plush 12A
2x 5g servo, 1x 9g servo
Rx Frsky 4ch (6g), voltage sensor
batery Lipo 2S 20C 800mAh (-1300mAh)
Tech spec:
Material:
skewers
velcro
fiber glass tape
Electronics:
Emax CF2805/2840kv
prop APC 7x4SF
ESC Plush 12A
