Like two layers of FB? No just ironed and one layer. I will tell what it doesn't need is the auxiliary rudder, doesn't do much for the flight characteristics
Vstab's are dry fitted, roll of tape for scale. After I finish printing some other stuff I'm going to 3d print a motor mount and then I'll start glueing things together.
I printed out a motor mount for the vector, and did a quick dry fit in the plane. I'm thinking of painting the fuse blue before I glue in the motor. I'm a little tired so I'm not going to do any work on this tonight, might just do some work on the Mosquito. I'm gonna try to get it ready to fly for next weekend.
I printed out a motor mount for the vector, and did a quick dry fit in the plane. I'm thinking of painting the fuse blue before I glue in the motor. I'm a little tired so I'm not going to do any work on this tonight, might just do some work on the Mosquito. I'm gonna try to get it ready to fly for next weekend. View attachment 155796
Painted the fuse, glued in the motor, installed the canards, and mounted the wing. I must have messed up a measurement somewhere because as of right now there isn't enough room to put on the prop...
Painted the fuse, glued in the motor, installed the canards, and mounted the wing. I must have messed up a measurement somewhere because as of right now there isn't enough room to put on the prop... View attachment 155828
