FT Versa scratch build. right wing 1 inch longer?
Talon2535
So i layed out my plans the way i have done on all my builds. I Downloaded the tiled plans. Then taped them together then taped them to my foam board.I cut out the parts and taped the wings together and this is when i noticed my right wing is 1 inch longer that the left. I haven't started gluing yet Do i need to start over? All the alignments seem off if i cut it to match.
Maingear
Flugzeug Liebhaber
I did the exact same thing with the Kraken. Lay your right side plans over the left and figure out which side is not exactly the same.
My mistake was I highlighted all the cut lines but one and the outer lower skin was one inch linger because the cut line was parallel to a grid line. I didn't notice until i had hot glue the wing half together. This threw the pod (twin motor) one inch inboard. I am making a center section for a Kraken blunt nose configuration and building the mistake into the other side.
Justin
