Well, I actually kinda forgot about this thread. I guess I should share my 2nd Viggen which is modified. About a year ago I started on my own FT Viggen in the stock 64mm EDF version. It was my first EDF jet. In may of this year, after maybe 20 or so flights, my fan ingested some tape holding my ESC down, destroyed the EDF, and my EDF is very hard to find replacement impellers for, so I retired my Viggen. Jump forward to September, and I have a 70mm 6s EDF from my x-29 (which didn't fly due to insufficient thrust as I was flying it on 4s). I was kinda bummed that my other jets weren't working, so I decided to build another one. There was just one problem: I was stuck without plans! There is another way to scratch build though, I took measurements of my old Viggen and essentially drew up the plans on foam board. It was a very time consuming process which used a TON OF MATH! In the end, I managed to build a Viggen. I did modify it, however. I changed the location and shape of the tail, and added a functional rudder. I also made the wing a straight delta. I also shaved a bit off of the canards. Here are some finished pictures:
I then proceeded to fly it twice on my YouTube channel. You can check out the video here:
Well, that's my modified Viggen. It's pretty good looking, I'm happy with it. It flies a tad faster than the other one(obviously, since I flew my previous one on 3s). That's my contribution to the group build! Have a great Friday the 13th everyone!
