Horizontal stabilizer / elevator installed, wing finished and installed.
I estimate that she'll come in under 2lb AUW (something like 30 oz). Need to figure out CG which will inform where to put the hatch. Also need to re-do the rear section of the pulse jet. When designing this piece I forgot to consider the thickness of the foam, so the exhaust diameter is about two thicknesses of foam narrower than I was aiming for. It might fly like this but given the length of the tube, the thrust losses might be excessive at such a narrow FSA. Or for this prototype I can leave it as is, try to fly it, and chop some off to get more thrust if needed. Will hack in some servos and EDF wires, glue on the pulsejet, and she should be good to maiden this weekend.
DamoRC
DamoRC
