The intermediate stringers were added to the sides of the fuselage and left long to be trimmed later. The two intermediate stringers on the bottom between F4 and F6 were also attached. These stringers simply butt against F6 in this build and are held with T-pins until the glue dries.
The plans will be updated with cutouts so this is no longer necessary. This added structure allows me a little freedom to perform the next step.
Since I planned poorly and the fiberglass locating rods aren't long enough to put F1 in place, I measured the distance between F1 and F2, then cut four temporary braces at that length and glued them to the back of F1. You could probably eyeball this when assembling everything, but I have a better way. Since F10, as designed, doesn't have any stringers attached to it yet I can simply slide the entire fuselage down until enough of the fiberglass rods stick out that I can slip F1 into place. The additional stringers I've added help hold everything in alignment, but be aware that they can still bow under load.
The horizontal stringers are glued into place to lock F1 in place. The supports on F1 are temporary and will be removed in time. The design has been edited to make them unnecessary.
The main stringer on the belly can now be installed, be aware that it cannot fully lock into its slot in F9 until the locating rod is removed, so just bend it off to the side for now. Be sure to check and recheck squareness of all formers until the glue dries. A few of mine slipped as they were drying. It shouldn't affect things too much, but is annoying.
This is where I ran into my first big "Oops moment." I was looking over the best way to get F-10 tied into the structure, and on going over the drawings realized that somewhere along the way I offset something too far. To be scale F10 should only be as wide as 2 thicknesses of DTFB. I can't do that easily, so in this case I had to sacrifice scale somewhat for ease of build, but F10 was far far wider than in needed to be.
The whole tail end had to be rethought and I came up with this:
This whole assembly will glue onto the aft end of F9. This has the added benefit of no longer requiring F10 on the build jig, so F1 can now fit with no issues.
For paper-on builds there will be a cutout in T1 for the rudder to slot into. For this version though, I won't need it.
On this build F9 slid a little on me when I glued the stringers and was out of square. Since the tail assembly is now gluing onto it, it needs to be. Simply cutting the glue joints on the stringers and regluing F9 on squarely fixed the issue. This time I checked it repeatedly as it dried and adjusted as necessary. More to come as I make progress.
