Tench745
So, with the stringers installed it's time to begin the skinning process. But wait! We need to add the hard-points for the landing gear before we lose access to these areas.
In this case I'm using a 1/2" x 3/8" poplar block that mounts into notches cut in F4 and F5. There are additional notches at the top of these formers for another such block, but I don't have the wood on hand a the moment, so we'll skip that bit for now.
There; now with that done we can glue in the custom stringer for the upper nose cowl section. There are some complex curves in this area that I'll need to play with a bit to figure out, so we'll come back to those later.
Sorry for the blurry picture, but this is the structure ready for skinning. The fiberglass rods remain in place to hold everything rigid while the skins go on. Once the side skins are glued in place the tail will be pretty stable and we can think about removing the support rods.
How do we attach the side skins? I'm glad you asked. Take a piece of DTFB (I'm using it paperless) and cut it just slightly oversized for the area you're going to be covering. Make a mirror image for the other side. Apply gorilla glue to all the stringers on one side, set the skin in place and tape in at both ends to hold it there while you repeat for the other side.
Now we come back in, pinning the sheet to the center stringer on each side to hold things square. Wrap tape around the edges to pull the skins tight to their respective formers. Check inside for any gaps between the stringers or formers and the skin; pin and tape as necessary to eliminate any you find.
I just want to point out, I'm not using masking tape here. I like to use "drafting tape." It's a little lower tack (less sticky) than masking tape and won't damage the foam quite as much if you leave in on for a while. Plus, I had a bunch laying around from hand drafting in college. If you're like me an hate standard masking tape with a passion, consider this or blue painter's tape. In the end, use what works for you.
More to come when I have time to do the write-up.
