RL has finally given me some time to update. Here are some assembly pictures of the hatch and hatch stiffeners. Also one of the cowl support blocks that give a spot to use screws to attach the cowl to the fuselage. Even though the cowl is a friction fit on the cowl supports it still works loose and slides forward into the prop unless they are positively attached. While the prop rubbing against the cowl gives it a throatier sound it'll wear off the front of the cowl pretty quickly. The windscreen gets glued just to the hatch and acts as the handle to open the hatch. I used gorilla glue and punched a lot of little holes in the hatch to give it something to grip.
