roversgonemad
As a man, and an engineer, I hate to even say this.... read the manual. That's the best tip I can give for assembly of that plane. If you have never assembled a balsa ARF before, a full read of the manual before you start can save you some headache. One of the first things I do, sometimes even before reading the manual, I run over all the covering with an iron and my heat gun. I run the iron over all the seams and then the gun over the whole surface, to get the covering nice and tight.
As far as the SPADs, there are a lot of options. I fly this one. It has an MDS .48 on the nose. It is a bit more robust than balsa, but it's also a bit heavier. When your Tower Trainer does meet its expiration date, the guts could easily transfer into a plane like this one.
