Thanks! I try to do at least one thing every day to keep progress going. It is also stress relieving for me to work on projects like this.
I'm ready to join the wing halves and everything looks good for wing alignment. This wing is bigger than my building board so the one end hangs off the board, but it's a happy accident as the wing support jigs were giving it to much dihedral, so since the wing tip jig is off the board it allowed the wing to drop slightly and now the center sections line up correctly, with less dihedral. It's a weird way to join the wing halves using support jigs and the upside down building method...not sure I like doing it this way, but I guess it is working, except for the dihedral issue and getting everything to line up properly. The issue of the dihedral gauge was brought up earlier in the build thread and if I were to do it again, I might even eliminate all the dihedral to simplify building and also make the plane more aerobatic (possibly).
