Jade_Monkey07
Hey guys, I'm looking for some help in picking some parts for future builds. I dont know anything about the modern gear at all. I've got some tight constraints in terms of size of my builds and my budget is tight too. But I'm looking to expand my builds capabilities and functionality
Currently I'm building foamies with wingspan around 50-70 cm with just a simple 2ch differential thrust pusher setup. The reciever I believe is locked to the transmitter, it came off a ready to fly foamy. I'd like to keep it around this size but add in more channels and more power.
Just having and elevator on top of the differential thrust would be wonderful.
Reciever
So I'm thinking of a small reciever with built in servos like this one
Banggood
Can this do Differential thrust? If not im open to suggestions if you know one like this that can.
Differential and elevator is all I really want at this point. But having the option to use thee extra servo for rudder, and add servos for ailerons later maybe.
I'm looking for an inexpensive reciever to go with it. I dont really need anything crazy cant afford a 300$ one. Will this one work with the above reciever?Transmitter
What batteries go with that reciever? I dont even know where to start there. I'd be open to multiple batteries different voltages(cell count?) for different power levels
And lastly motors. Currently I'm running two of these little brushed motors. 42mm props.
Can these be pushed any harder with just a bigger battery(more voltage)? I feel like they dont spin as fast as they could, is this the reciever board maxing them out? or is it the voltage from the battery not high enough? should I go with a set of slightly bigger motors? I just always wish they had more top end. Brushless or permanent magnet? Is one lighter than the other? Given the size of the planes weight is a factor in all these selections.
Any help would be great, I'm feeling in over my head trying to match parts. I've watched all the beginner videos but I'm still confused
Reciever
Banggood
