Hello guys,
I have trouble with my KK 2.1.5 Board from hobbyking, I probably made the wrong connections and now I can see the led screen only to light up and nothing else to happen, probably is f** burned up. Is there any complete tutorial to show me how I must make the connections? How I am going to connect right my cables from my speed controllers and my channels from my receiver? I searched online and I did not came to any complete video that Explains everything. As a beginner I am having trouble on how I am going to connect everything up.
If I want to test my board from where I must give power ? Can I give it from the right side (H1,H2,...) or not? If I give it from the left side then my board is burned?
How I can provide as Input Voltage: 4.8-6.0V, when I am using a 4S battery that gives me 14 VOLTS?
Do I need only to connect the cables from the speed controllers so I can provide power on my board?
Can I connect my receiver with my battery and then with a servo cable direct to give power on my board or not?
If there is a complete tutorial with a diagram or video on how to make it right for a tricopter will be the answer optimal.
Thanks in Advance!
Thanks in Advance!
