Ideally, for aerial mapping, I'd think you'd want a plane that flies as straight and level as possible. And even with an autopilot controlling the yaw, pitch, and roll of the plane, that alone may not be precise enough to mesh with the accuracy of the GPS side of the equation. Even under the best conditions, a puff of wind may pitch or roll the plane, resulting a picture many meters off-line...or in the case of the yaw axis...off course.
So instead of a fixed position camera, now you are looking at a precision gimbal holding the camera. This would improve accuracy of the position of pictures being taken of the ground below.
The Versa wing has been proposed, but the problem with wings is that they fly like a drunken sailor. And having the wing set up as a pusher is the worst of all worlds. The Kracken is a puller, but it cost's $85.00, and is a limited run...
Which craft would you then recommend to fly not less than 30 min on auto pilot with GoPro.
Regarding the "Durability", I believe you mean the foam frame. If so, then I am ready get 10 wings and switch to new one for every project
Please, share your opinion.
Are you sure you want to be building kits?
As many as 10 of them at a pop...lol...
The durability of a plane this size, does become an issue.
Do you want to constantly be in repair mode?
It sounds like money is not a problem...
It also sounds like this is a commercial venture, where time is money...
In my opinion, there is not a FliteTest kit available to fit your needs.
So why not buy an airframe?
A plane that gives you room to grow... possibly for a larger camera...or more batteries.
ReadyMadeRC has a number of larger platforms designed for jobs like aerial mapping.
Here are the likely candidates...Air Titan, Penguin, and Sabre....
http://www.readymaderc.com/store/index.php?main_page=index&cPath=112_113
The Penguin is the smallest of the lot.
http://www.readymaderc.com/store/index.php?main_page=index&cPath=112_113_117
An easy to set up Penguin for $99 that readily fits your needs vs. $85 for a Kraken Kit that requires multiple hours of building, and in the end, may not be adequate...that's no contest...
The ReadyMadeRC Penguin is what I'd look at...
