TheSwedishLoller
Hello everybody!
I am trying to figure out what is wrong with my quadcopter. I've made the body by myself by some aluminum and plastic, and it is very solid. I am using TURNIGY Plush 25amp Speed Controllers, Turnigy D2836/9 950KV Brushless Outrunner Motors, a normal Turnigy 2200mAh battery and the red MultiWii Pro. Everything from HobbyKing. The problem is that it is like "dangling" left and right all the time, like it is overcompensating, but only with the "roll"-axle. If I take it up high and then letting it fall, it becomes stable, but when I increase the throttle again, it starts dangling again.
I am using the MegaPirate software for the MultiWii Pro, mainly because I can't get the original software to work. The problem I have with the original MultiWii software, both 2.1 and 2.2, is that I can't find any place to calibrate the endpoints of the sticks on my transmitter (I'm using the incredibly cheap "Hobby King 2.4Ghz 6Ch Tx & Rx V2 (Mode 2)" radio). So when I arm the quad, the motors starts spinning directly, so fast that it almost lifts from the ground. I don't have that problem with the MegaPirate software, because it is possible to calibrate the endpoints on the radio in Mission Planner. So if you know how to do this with the original software, I would be amazingly glad if you could tell me!
I use the code that Jared showed in this video:
I will give you some pictures of my quad:
I hope that someone have any idea what could be wrong. Probably there is something with the software which I need to change, because it simply seems to be overcompensating. I can go out and fly it and film from the ground if you guys want to.
Patrik
Patrik
