Hello everyone, i need your help and advice.
flying my Hexacopter DJI F550 between two buildings, it wasnt windy where i was but 15 feet of the ground the hexa start shaking really bad, with strong wing, i lost visual and it landed on one of those ponds that new buildings are so fond of it. I know its all my fault, learned my lesson.
the lights were still on UNDER WATER
now, what do you recommend to clean it up and if possible make sure the electronics work.
what i have done:
>i took it out of the water and disconnect the battery
>i walked home and all the way here i hold it in a position that water was dripping.
>got home and opened up everything, disassemble everything and made sure i can dry things up in the shade
>I opened the NAZA M lite, all the screws and surprisinly inside it was only one drop of water which gives me hope
>i opened the futaba receiver and dry everything up with paper towel, gently
>i took the propellers out
>i disconnect all the ESC and they look dry
>i will let it dry for a couple of day before i reconnect everything and try it
so except for the solder parts, everything looks like a fresh kit
some people recommended me isopropil alcohol to clean up the electronics
anything else that i should do? any advice?
Thank you all
what i have done:
Thank you all
