Hello
following the advice of Hai-Lee I open this thread to see why I can not fly the TT in conditions
first I will tell what you have installed
configured in 3ch
Racestar BR2205 2300kv engine
6,5x3 folding propeller
nano-tech 2s battery 850mah 25-50C
I also have a nano-tech 3s 450mah 25-40C
change the radio for a flysky I6 to have EXPO, since the hk-t6 did not have it and I left it for the simulator removing the power to the transmitter module
I have removed the angle of thrust because I had to do wrong power-pod as it was going far to the right and when I hit the stick to the left it went straight
the other day to a little wind and making a sudden turn fell to the head, gave a good blow but did not seem to have something important
yesterday I split it in two, although fortunately the wing is in one piece and straight, also towards a bit of air
I was like crazy for going out to fly
It is well balanced and when rebuild it I will post the weight, since the European foam board is heavier because it is covered with a thicker paper
I want to know if I need more practice or I have it wrongly configured
Thank you
configured in 3ch
Thank you
