I have built the scout and the tiny trainer. Both have done the same thing when trying to fly. They bank hard to the right immediately and go straight into the ground. I had the scout up once but then the wings crumpled mid air. I make sure everything is leveled out and check the check beforehand and I have the same issue.
Also the tiny trainer is a bit nose heavy even when pushing the battery back as far as it can go. The battery I’m using is the TATTU 850mAh 11.1V 45C 3S.
Thank you!
Thank you!
