So I live in central IL. Corn fields all around the problem I have is it's always windy here usually 5-10 mph wind but it's not unusual for it to be 20 mph winds. I first scratch built a simple soarer which I crashed a lot. I also built a guinea pig which is not operational yet. But because I kept crashing the simple soarer I used experimental aircrafts tube idea and then I built an 8" sleeve to slide the tail boom and nose boom into so when I crash and the nose is all banged up I can just pull the noise off and put another one on. If I don't crash the plane will be 200 yards away because it keeps getting blown away. The reason I crash so much is I can't get the plane high enough to make mad takes other wise it will blow away. Basically what is the answer to kind of fight the wind. Should I buy 2 more motors and get the guinea pig up with 4 motors and some weigh in it. Any suggestions will be appreciated. Thanks Brian
