Maingear
Flugzeug Liebhaber
The only hold up in my project is sanding the profile in the TE/ailerons and LE.
What type of wood should I use where the sandpaper is placed?
Do I need to make different sizes for the changes in grit used?
Can I make the TE tip to a point? (the airfoil's TE is sharp)
How do I keep the block from digging into the wing on the spar side of the sanding block?
Can I glue 1/4" balsa so I don't have to buy TE stock?
Anything I didn't think of?
Thank you!
Justin
Thank you!
Justin
