ThFPVFiles
Hello everyone, this was my first time messing with FPV and I bought a Fatshark receiver and transmitter. After learning that the receiver is specifically designed to work with the Fatshark goggles, i decided to try it before putting it on the shelf. After flipping through the channels I found that the receiver has a default receiving channel of 8 (it is an 8Ch receiver). So if you want to start out with a ground station or cheap goggles and move on to the Fatshark goggles (as I do) then you can use the last channel the receiver has instead of buying 2 different receivers. Is it worth it?. Are you willing to deal with 1 channel until you upgrade? It's up to you! Hope you enjoyed this post, instructions on how to use the receiver w/o the goggles will be posted shortly.
