I think I bought a laser.
FlamingRCAirplanes
3Dman 2GT Timing Belt Aluminum Gear Clamp Mount Block 9X40mm (10PCS) https://www.amazon.com/dp/B08XVVQW6G/?tag=lstir-20
CNC 3D Printer Driver Kit, MYSWEETY 39PCS 3D Printer CNC Module Kit, 3D Printer CNC Controller Kit, Nema 17 Stepper Motor & Stepper Motor Driver with Heat Sink https://www.amazon.com/dp/B08PYVPGNW/?tag=lstir-20
Silvery Screw Nut Kit for 2020 2028 Series Conner Bracket Connector, 40Pcs M5x10, M5x8 Stainless Steel Hex Socket Button Head Cap Screws Bolts, M5 Slide T Nut, M5 Drop in T Nut and Washers https://www.amazon.com/dp/B08VGVDKPT/?tag=lstir-20
Color = Silver
Befenybay Upgrade 2020 Profile X-axis Synchronous Belt Stretch Straighten Tensioner for Creality Ender-3/Ender3 Pro/Ender3 V2/CR-10/ CR-10 V2/ CR-10 V3/CR-20 Pro https://www.amazon.com/dp/B07XL41QNH/?tag=lstir-20
Size = 2020
Style = Black
heyous NEMA17 Stepper Motor Mount Plate 3D Printer Openbuilds Aluminum Alloy Stepper Motor Mounting Plate Suitable for NEMA 17 Stepper Motors/V-Slot Linear, Black https://www.amazon.com/dp/B08JTTTZ5K/?tag=lstir-20
Quantity = 3
boeray L-Shape Interior Inside Corner Connector Joint Bracket with Screws for T Slot Aluminum Extrusion Profile 2020 Series Slot 6mm 10pcs https://www.amazon.com/dp/B01GZYK84C/?tag=lstir-20
Color = Silver
10-Pack 2020 Series Aluminum Profile Straight Line Connector, Extended Length Bracket Fastener with M5 Screw for T/V Slot 6mm Aluminum Extrusion Profile Connect Parts https://www.amazon.com/dp/B094G8XC22/?tag=lstir-20
Befenybay Upgrade 2020 Profile X-axis Synchronous Belt Stretch Straighten Tensioner for Creality Ender-3/Ender3 Pro/Ender3 V2/CR-10/ CR-10 V2/ CR-10 V3/CR-20 Pro (2020-1, Black) https://www.amazon.com/dp/B087YWMHM2/?tag=lstir-20
Style = Black
Size = 2020-1
Quantity = 2
V Slot Gantry Plate,POM Wheels Set with Plate for Aluminum Extrusion,an Extra Pack of 2PCS Eccentric Spacer and 2PCS Round Column for Replacement. https://www.amazon.com/dp/B0986PYTNJ/?tag=lstir-20
Color = V slot gantry plate
Size = eccentric spacer height 6mm
Quantity = 3
100-240V Hot Wire Foam Cutter, Jhua Hot Knife Foam Cutter Electric Styrofoam Cutting Tool, 572℉ Foam Board Cutter with Cutting Machine Pen for Styrofoam Foam Cutting, Arts, Crafts DIY (5cm/1.97in) https://www.amazon.com/dp/B091KCH3R6/?tag=lstir-20
Size = 5cm / 1.97in
KeeYees 5M GT2 Timing Belt 6mm Width + 4pcs 20 Teeth 5mm Bore Belt Pulley Wheel + 4pcs Idler + 4pcs Tensioner Spring Torsion + 2pcs Gear Clamp Mount Block with Allen Wrench for 3D Printer RepRap https://www.amazon.com/dp/B07JKT5BZQ/?tag=lstir-20
Prolee 10 Pack 2020 T Slot Aluninum Extrusion European Standard with 400mm/15.75 Inches Length, Anodized Linear Rail for 3D Printer and CNC DIY, Black https://www.amazon.com/dp/B09BFM9MHK/?tag=lstir-20
Size = 400mm/15.75”
Color = Black
48 PCS 3D Printer POM Pulley Wheel Set with Pulley Bearing Included 16 PCS POM Wheel 16 PCS Eccentric Spacer 16 PCS Round Column for Creality Anycubic Anet Series 3D Printer Ender 3 https://www.amazon.com/dp/B098797LW4/?tag=lstir-20
Color = Black POM Wheels 48pcs
Size = Eccentric Spacer Height:6mm
Marzipan
@FlyerInStyle @KN4IUU weeell, please keep us in the loop, I am very curious to see how that goes. if it's easy enough, I might jump on it as well as that would make things so much easier!!!
Google is your friend: cheap laser cutter plans, DIY laser cutter.........
that's true...but if someone has experience in building one already, they may have insight on which build plans / methodology are the best of all the info Google will give you.
FlyerInStyle
I also have a 3D printer so I have an idea how it works
oh. well. I will probably be going off of your build! having a 3d printer definately helps. I have a arduino lookign for a home, so I am going ot be watching this!
(Sorry, @trey ) But we mightve taken over this thread for a little bit)
FlamingRCAirplanes
I am not thinking I have to 3D print anything. Just using it for ideas.
FlamingRCAirplanes
oh. ok. they have an inbuilt pot?
They have what is called a rotary encoder. That is very similar. Except they need to be calibrated every time and that is why on the ends of the X and Y axis’s there is little switches. It tells it how much it turned and then it knows where it is.
FlyerInStyle
ooh. thanks for the clarification!
FlamingRCAirplanes
Doing some work with the parts I got on Christmas!!
