3Dman 2GT Timing Belt Aluminum Gear Clamp Mount Block 9X40mm (10PCS)
https://www.amazon.com/dp/B08XVVQW6G/?tag=lstir-20
CNC 3D Printer Driver Kit, MYSWEETY 39PCS 3D Printer CNC Module Kit, 3D Printer CNC Controller Kit, Nema 17 Stepper Motor & Stepper Motor Driver with Heat Sink
https://www.amazon.com/dp/B08PYVPGNW/?tag=lstir-20
Silvery Screw Nut Kit for 2020 2028 Series Conner Bracket Connector, 40Pcs M5x10, M5x8 Stainless Steel Hex Socket Button Head Cap Screws Bolts, M5 Slide T Nut, M5 Drop in T Nut and Washers
https://www.amazon.com/dp/B08VGVDKPT/?tag=lstir-20
Color = Silver
Befenybay Upgrade 2020 Profile X-axis Synchronous Belt Stretch Straighten Tensioner for Creality Ender-3/Ender3 Pro/Ender3 V2/CR-10/ CR-10 V2/ CR-10 V3/CR-20 Pro
https://www.amazon.com/dp/B07XL41QNH/?tag=lstir-20
Size = 2020
Style = Black
heyous NEMA17 Stepper Motor Mount Plate 3D Printer Openbuilds Aluminum Alloy Stepper Motor Mounting Plate Suitable for NEMA 17 Stepper Motors/V-Slot Linear, Black
https://www.amazon.com/dp/B08JTTTZ5K/?tag=lstir-20
Quantity = 3
boeray L-Shape Interior Inside Corner Connector Joint Bracket with Screws for T Slot Aluminum Extrusion Profile 2020 Series Slot 6mm 10pcs
https://www.amazon.com/dp/B01GZYK84C/?tag=lstir-20
Color = Silver
10-Pack 2020 Series Aluminum Profile Straight Line Connector, Extended Length Bracket Fastener with M5 Screw for T/V Slot 6mm Aluminum Extrusion Profile Connect Parts
https://www.amazon.com/dp/B094G8XC22/?tag=lstir-20
Befenybay Upgrade 2020 Profile X-axis Synchronous Belt Stretch Straighten Tensioner for Creality Ender-3/Ender3 Pro/Ender3 V2/CR-10/ CR-10 V2/ CR-10 V3/CR-20 Pro (2020-1, Black)
https://www.amazon.com/dp/B087YWMHM2/?tag=lstir-20
Style = Black
Size = 2020-1
Quantity = 2
V Slot Gantry Plate,POM Wheels Set with Plate for Aluminum Extrusion,an Extra Pack of 2PCS Eccentric Spacer and 2PCS Round Column for Replacement.
https://www.amazon.com/dp/B0986PYTNJ/?tag=lstir-20
Color = V slot gantry plate
Size = eccentric spacer height 6mm
Quantity = 3
100-240V Hot Wire Foam Cutter, Jhua Hot Knife Foam Cutter Electric Styrofoam Cutting Tool, 572℉ Foam Board Cutter with Cutting Machine Pen for Styrofoam Foam Cutting, Arts, Crafts DIY (5cm/1.97in)
https://www.amazon.com/dp/B091KCH3R6/?tag=lstir-20
Size = 5cm / 1.97in
KeeYees 5M GT2 Timing Belt 6mm Width + 4pcs 20 Teeth 5mm Bore Belt Pulley Wheel + 4pcs Idler + 4pcs Tensioner Spring Torsion + 2pcs Gear Clamp Mount Block with Allen Wrench for 3D Printer RepRap
https://www.amazon.com/dp/B07JKT5BZQ/?tag=lstir-20
Prolee 10 Pack 2020 T Slot Aluninum Extrusion European Standard with 400mm/15.75 Inches Length, Anodized Linear Rail for 3D Printer and CNC DIY, Black
https://www.amazon.com/dp/B09BFM9MHK/?tag=lstir-20
Size = 400mm/15.75”
Color = Black
48 PCS 3D Printer POM Pulley Wheel Set with Pulley Bearing Included 16 PCS POM Wheel 16 PCS Eccentric Spacer 16 PCS Round Column for Creality Anycubic Anet Series 3D Printer Ender 3
https://www.amazon.com/dp/B098797LW4/?tag=lstir-20
Color = Black POM Wheels 48pcs
Size = Eccentric Spacer Height:6mm
