evranch
Updated to the latest firmware last week to get the new notch filters etc. Copied all my settings over and my quad flies great, with 2 issues:
- Full throttle punchouts roll the quad to the right
-The props will no longer idle when armed, maybe one or two will flick a bit. I need to give a throttle command sufficient to take off before all 4 rotors will spin up. With folding props I want them all spun up before I try to take off. Solved by switching back to DSHOT
I suspect that applying full throttle is giving all the motors 100% throttle, which means it can't stabilize. It worked great with the older firmware, though. Is there a new setting that makes punchouts apply 100% or something? Or a change in ESC calibration?
I tried increasing the motor idle % but still, the props aren't spinning at idle. I'm at 15%, same as I used to have it set to, and don't really want to go much higher. I don't need it trying to fly itself at idle...
