Random_rc
hello,
i was wondering what your p and i gains and limits are for the flitetest electrohub for FPV. and also when i have the auto level off and i fly it still is in half auto level because the quad twitches a little bit, like when i come to a stop
now i am using a kk2.1 with one of the latest Stevies firmware (re-flashed about a month ago)
also if one is looking at getting a electrohub, buy one they are really good the are as solid as a rock. great size, nothing to fault except you will need zip ties because the zip ties break in hard landings. if you are using the dt700 like i am or the dt750's then the discs have the right holes (not all), but you will need a 25mm m3 bolt and a m3 lock-nut or m3 nuts with thread-lock.
and if anyone was wondering can you fly with a 11x4.7 prop, you can there is about a >5cm gap between the closest props. and the gopro hero3 on 1080p wide you will only get a little bit of prop in your view ( like you will only notice it if you look for it and when it is stopped).
