Hello Everyone,
I'm having a bit of trouble tuning my first tricopter with a KK2.1 FC with stock firmware. I have built and flown multiple aircraft with my most recent being an H-Quad and a 450 size Hex; both of which were scratch builds. I had no issues getting them sorted and flying but I just can't seem to get this tricopter to act right.
I did go through and completely setup the new kk2.1 board before trying to fly and then followed Davids setup video step by step. Well with every step that applied since he was tuning a KK2.1 with Stevies firmware and I am running stock.
***Specs and Settings at bottom of post***
I tried using some of David's (RCExplorer) settings as a base but the thing was really wobbly (low oscillations I think) in self level and sluggish with self level off.
I tried raising P and I gains and limits in various configurations but never could get it locked in. I was able to get close with P set at about 150 and P limit at 100 and I at zero but as soon as I started adding I gain it would start wobbling again. I tried lowering the P setting and limit all the way down to 15 and things just kept getting worse.
I would adjust P and I settings first then go back and try adjusting the limits.
I understand that the P and I settings basically adjust sensitivity with P producing high oscillations and I producing low oscillations when too high and the Limits adjust how much input is given but I still can't seem to get this thing to act right.
Below is Davids recommended settings but everything is really sluggish and self level wobbles with these settings.
Roll and Pitch gains:
P Gain: 20
P Limit: 100
I Gain: 11
I Limit: 20
Rudder gains:
P Gain: 80
P Limit: 20
I Gain: 80
I Limit: 10
I am running The Flite Test Power Pack D and I also auto tuned the ESC's using the KK2.1 Throttle-Up-Press-Buttons-1-and-4-While Powering-On method. Everything is mounted on the ElectroHub with ten inch booms.
Any help would be greatly appreciated!
Thanks!
P Gain: 20
P Limit: 100
I Gain: 11
I Limit: 20
Rudder gains:
P Gain: 80
P Limit: 20
I Gain: 80
I Limit: 10
Thanks!
