Marty72
As a beginner, I would agree. One thing that helped me a lot with the Scout was detuning the ailerons. ie, I set up a low rate for them, that was really low. I found that for just simple flying (Scout spec build) 60/40 on the ailerons was plenty (and it kept me from crashing). The elevator and rudder weren't an issue for me, I kept them around 85/40. This is just my experience. Most of my crashes on the Scout 1.0 were due to me dropping the wing down on turns way too far, and crashing. The low rates slowed things down and allowed me to keep the plane in the air longer. BTW, my first unsuccessful flights with the Scout were using low rates of 70/30 on all surfaces.The Scout is really beginner friendly and just fun to fly!
On the Scout 2.0, I made the control surfaces with more range that the spec. I used the middle on on the servo arm. With that set up mechanically, I have three rates for the Scout 2.0. For landing and take offs currently I use 40/40 aileron, 60/40 elevator, 75/40 rudder for my low rate. High rate I use 100/30 for all surfaces. I have a medium rate as well, right between low and high. After I get the bird up, I switch to high rates. I know some here will think this is crazy, but it works well for me. BTW, I can do loops with ease and some other maneuvers in the low rates. I find the low rate helps me with landing, I'm forced to be smoother, slower and if I do make a mistake, it happens slow enough for me to have a chance to recover. I find it great for flying low and slow as well. That's my experience, as a beginner with this plane.
For those who may just be tuning in, My Scout 2.0 is a replacement for the heavily crashed and damaged 1.0. I believe I crashed the 1.0 on my first 8 attempts to fly it. It went through a lot and still looked and flew good until it's final epic crash (some pages back).
Best of luck on your Maiden.
