Under Construction:
Micro Sopwith Camel
Micro Spitfire
Hughes P21-J MkIII Devastator Swappable
Micro Russian Thunder
39" Messerschmitt Bf 109
42" Gloster Gladiator
Mighty Mini Bf 109
Hughes P21-J Mk III Devastator
Swappable Floats and Skis
Finished Builds:
Mighty Mini A6M Zero Swappable
Build Thread
Mighty Mini A6M Zero v1.1 Full
Mighty Mini A6M Zero 1.1 Tiled
AUW - TBD
25" Wingspan
Designed around Power Pack F
Motor: 2204 2300kv
ESC: 12 Amp
Prop: 5030-6045
Servos: 4 - 5 gram
Battery: 800mah 3s-4s
42" Mitsubishi A6M Zero Swappable
Build Thread
42" Mitsubishi A6M Zero Swappable Beta Plans v.2 - Full
42" Mitsubishi A6M Zero Swappable Beta Plans v.2 - Tiled
Scale DTF Floats for 42" Zero - Tiled
AUW - TBD
42" Wingspan
Designed around Power Pack C
Motor: 2215 1180kv
ESC: 30 Amp
Prop: 10x4.7 SF
Servos: 4 - 9 gram
Battery: 2200mah 3s
Micro FT Flyer
Tiled Plans
All Up Weight 70 grams
16" Wingspan
6.4g HD1610 3400kv Motor
5030 Gemfan Prop
6AMP Plush ESC
3g Servo x2
Full Size Receiver (Cover Removed)
Gift Card Firewall and Servo Horns
180-260mah 2s (Actually, the plane has a ton of power, it'l haul a 500mah 2s just fine and fly for a long time)
10 Minute Flight times with 260mah 2s
Micro F22
Tiled 8.5x11 Plans
Full Plans
Decal Plans Full
Decal Plans 18x24
Decal Plans 8.5x11 Tiled
Jumbled up Build Thread:
http://forum.flitetest.com/showthread.php?21299-Micro-Indoor-Flyers-Re-Purposed-Designs
13" Wingspan
5030 Gemfan Prop - 5" Maximum Prop Size
6AMP Plush ESC
1.7g Servo x2 - Dual Elevon Setup
Micro Receiver
180-260mah 2s
6 Minute Flight Times with 260mah 2s
Micro Sopwith Camel
Micro Spitfire
Mighty Mini Bf 109
Finished Builds:
Build Thread
AUW - TBD
25" Wingspan
Motor: 2204 2300kv
ESC: 12 Amp
Prop: 5030-6045
Servos: 4 - 5 gram
Build Thread
AUW - TBD
42" Wingspan
Motor: 2215 1180kv
ESC: 30 Amp
Prop: 10x4.7 SF
Servos: 4 - 9 gram
Battery: 2200mah 3s
Micro FT Flyer
Tiled Plans
16" Wingspan
5030 Gemfan Prop
6AMP Plush ESC
3g Servo x2
Micro F22
Tiled 8.5x11 Plans
Full Plans
Decal Plans Full
Decal Plans 18x24
13" Wingspan
6AMP Plush ESC
Micro Receiver
180-260mah 2s
