mjcp
Hi all,
I'm mid build of an F-14 profile pusher, following the plans from RC Groups for the MDC F-14 from c. 2005->
Thought I'd pop a few pics up as i go
I'm building from foam board (the original plans are for 6mm depron)
the wings are a flat section, no airfoils! They have a carbon spar and pivot around the large circle in the last pic. The servo is a 9g metal gear one that I had on the shelf. alas its now stripped itself after I got some glue outside of the hinge when attaching the top deck.
Motor and power will be 2200kv running off a 1500 mAh 3s (50-70C). Control is via elavons on the tail only (with throttle and wing sweep channels)
mjcp
mjcp
