mig 31 firfox scratchbuild
wind1234
#5
its 4 ft long 3 ft wide made with fan fold blue foam it started off like a profile plane then i made bulkheads the skined it in foam then 1 3/2 balsa sheet.....im not sure how scale it is just kinda going from pictures tryin to keep it light as possible right now its at (570 g. or 1 lb 4 oz.) dry weight nothing installed....im not sure on the power system yet .....it first started out as i was going to use my 2 64mm powerplant out of my dynam a10 but after doing a quick thrust test i was only getting 10 oz. of thrust per fan..i thinks its only a 330 watt system....so i scraped that idea and ordered a couple other sets of fans to see what i can get out of them (77mm and 89mm) i got a couple sets of motors for each a (420 watt set and a 1300 watt set)and a medly of batteries i still might need to order another battery with a high c rating for the 1300 watt setup.....but the project is on hold till i get my fans from hk for size reference cause i will have to install them before i finsh skinning the bottom of the plane : )
wind1234
#9
yes deffinatly need to do something cool with the paint.......been thinking of doing something like a futuristic police plane (black/white) with working red and blue strobes : )
#14
just got done checking the balance on the 77mm fans and they are right on the money : ) they are the haoye fans from hk highly recomend for like 17 bucks a peice...wish i had my motors to put in them i ordered the exceed motors from hobbyparts for like 13 dollars a peice i hope they work out ok : ) i got a 3s 4s and 5s battery to do my fan testing when everything gets in...i got watt meters and rpm meter to get some real numbers and see whats really going on power wise...cant wait to get back into the build full force ..thanks for looking guys
