leaded50
Push-pull aircrafts was of a less common configuration, where a single conventional fuselage has an engine at either end; the Dornier Do 335 fighter and also Cessna Skymaster used the same arrangement. For light civil aircraft, the aim was to combine the performance of a conventional twin-engined aircraft with the ease of handling of a single-engined one.
As an executive transport with between four and seven seats, depending on engine power , the French made in the 60´s the Moynet 360 Jupiter. Only two prototypes was buildt.
I had some foamboard and a couple small motors laying around and decided make a "fast build" with conventional FT style , pretty square fuselage, as also the original plane had, and a single board wing.
