Recently I got my hands on a FliteTest VersaCopter V2.
Specs:
Flite Test VersaCopter V2.0
Power Pack E (Racing Mini QuadCopter)
Naze 32 Flight Controller Rev 5
FrSky XSR 2.4 Ghz ACCST Receiver
The build which I will detail below was pretty straight foward and if you listen to the podcast you'll get to hear how tough this beast of a quad is.
While in Ohio I was having a riot ducking around/going through trees and the VersaQuad put up with it.
This while not running any of the proper settings. I merely flashed the FC and went flying.
Initially the booms troubled me but then I hit a tree and the ingenious design shined through.
Simple re-level the motor and go flying again. The entire weekend I only broke 1 triple blade prop.
Build:
While not a plug and play sort of project it is something you can defiantly build.
Just take your time and study wiring.
- Really impressed with the packaging.
- I have become a fan of power distribution boards for sure.
- I did have an issue with one of my booms being a touch too big so it does sport some scars from the install.
- I do recommend you switch to the lock nuts vs the prop caps because in a crash those will spin off.
Still working away:
While I was at FT HQ I did take note of their setup as I'm still trying to figure out how to mount my FPV kit and keep it protected.
I recently ordered the AP mount but have not installed it yet.
- Alex's AP quad at HQ!
I'm still playing with props and recently installed Beta Flight so I can have access to Air Mode.
Other consideration:
I've ordered a simple 5/12V power board to compliment the setup. Specially since I intend to run 4S on the VersaCopter.
I also have an ant cable coming in for the FPV kit.
I'm going to move the FPV hard around once everything is sorted because leaving it inside means I can change channels or turn it off quickly if I interfere with someone.
Still looking forward to running this at the field with my buddies.
Specially once I have it all dialled in.
Specs:
Build:
Still working away:
