lsutiger607
I've watched the FT Naze 32 board setup video (for the 10th time) and wanted to ask for assistance. I'm trying to setup my new Naze Acro board on my quadcopter. I went through all the steps in the video but cannot get my throttle, roll, pitch and yaw signals from my receiver to register with the board. I have successfully accomplished the following: flashed Naze V10 firmware, installed chip drivers, calibrated accelerometers, tested each motor for correct positioning and direction. What is perplexing is that my Aux 1 and Aux 2 channels work correctly are are being recognized by the cleanflight software. Again however, TAER just shows frozen at 1500 on the receiver tab of the configurator and will not respond to receiver inputs. I have tested the receiver independently using simple servos and all channels respond as they should. I am powering the receiver via an external BEC as my ESCs do not come equipped with them. It seems that I have tried every possible combination from the configuration tab of the cleanflight software but again, to no avail. Why am I able to get accurate readings from Aux 1 and 2 but not from the other 4 channels? Also, I checked the latest firmware for my Frsky D8R-II Plus receiver and am assured that it is loaded on the receiver. Also have checked all soldering points to the board as well as tried various cables to try to isolate a fault.
Any help would be appreciated.
