I'll start getting (what I assume are) voltage warnings after only about 3 minutes of flight. When I set it down, my voltage is at 11.5, which is 3.8V per cell! I have the warning set to 3.5, and by the time I set it down, it's gotten to be a pretty insistent warning. Looking at my settings, I have minimum cell voltage set to 3.3 (default), and warning cell voltage set to 3.5 (default). The voltage scale is set to 110 (default). When I set it down, the batteries are not particularly warm, so it's not like they're actually drained but are reporting the wrong voltage (from what I can tell). Connecting them to the charger tells me 11.5V as well, so it's also not a discrepancy in the voltage monitoring circuit (in so far as they both return the same value).
Anybody know what I can do to fix this? I don't want to disable to voltage alarm and fly on a timer, but if the voltage alarm is simply wrong, there's little else I can do. It's also not just when I'm punching the throttle or something. I can be simply hovering, after an alarm beep, and hear the beep again.
Alternatively, could it be beeping for some other reason?
