I have a custom build Tricopter (using the RCexplorer frame; and most of the recommended build components)
Its set up with the Naze32 and Lemon featherlite DSM2 transmitter. I've programmed one of the aux switches for arming/disarming; and a separate switch to toggle horizon mode.
The maiden flight was fine and I didn't have any problems at all during the half an hour.
However subsequent flights; I'm having some issues with arming the tricopter;
I would power on the tricopter and my Tx, and after the Naze32 calibrates, i am able to arm it. I can throttle on into a hover, but subsequently i would lose control of the throttle, and can't throttle up or down; but the props are still spinning under power. I would disarm and the props would stop. After this; i cannot re-arm the tricopter again. Or sometimes it would arm itself but have the same issue.
I've connected to CleanFlight and found that the board would register that the Arming switch is in the on position but the board won't still arm.
What do you guys think i should do?
One possible cause that I can think of is that the board is programmed using Baseflight (but only because i can't seem to be able to do it on Cleanflight) but the aux switch is configured using Cleanflight (also because i can't seem to be able to do it in Baseflight).
