Hello guys, i'm new around here...
Have a question for you all,
I've just bought a NAZE32 rev5 controller and a GPS (NEO-6M)...
I could setup everything and it should be, but my issues started when I decided to plug my GPS on naze32.
Currently as I saw on naze32 manual, pins 3 and 4 must be set to tx/rx on my GPS.
It's everything OK at this moment, I can see my gps position on Clean Flight....
But, as I have a PWM receiver (Turnigy XR7000), I can't use pins 3 and 4, because it's now set to GPS...
Ok, but on naze32 manual, it says that I have to change the pins 3 and 4 to 5 and 6, as you can see here:
http://www.abusemark.com/downloads/naze32_rev3.pdf
"When GPS feature is enabled, channels 3 and 4 are are used for 3.3V GPS connection. (3:TX, 4:RX). with CPPM receiver, these are normally unused, with standard receiver, connect AIL to 1, ELE to 2, THR to 5, RUD to 6, and AUX1/2 to channels 7 and 8."
That what I did.
So :
Pin 1 - Channel 1 - AIL
Pin 2 - Channel 2 - ELE
Pin 3 = GPS
Pin 4 = GPS
Pin 5 - Channel 3 - THR
Pin 6 - Channel 4 - RUD
Pin 7 - Channel 5 - Aux1
Pin 8 - Channel 6 - Aux2
So my problem is:
On Clean's Flight "RECEIVER" tab, I can receive AUX1/AUX2 channels only!...
About ROLL/PITCH/YAW/THROTTLE... nothing at all...
Roll , Pitch, Yaw, they are all at " 1500 ",
Throttle at 885.....
My receiver mode is set to "RX_PARALLEL_PWM" (one wire per channel)
Any idea what i'm missing????
Thanks in advance!
That what I did.
So :
Pin 3 = GPS
Pin 4 = GPS
So my problem is:
Thanks in advance!
