Help! Need help binding X8R
FDS
Make sure both are the same firmware and protocol (x9 Lite is ACCESS, some older receivers are ACCST) then follow the instructions. Be sure you have the right sub protocol like D16 selected in the model setup menu.
#3
I’m kind of new to taranis and everything, so i barely even know the controller lol. However, when i tried to go to the binding part, i think it said “D16 ACCST” or something. Is that right?
FDS
You need to check that your receiver is the same, look on it, it will have ACCST on it if it’s an older one. If you bought it new recently from a reputable supplier it should be an ACCESS compatible one, which will work with your transmitter.
That is the right setting screen. Lots of good set up videos on YouTube too.
