Hello to everyone!
Need little help for tricopter build.I am thinking of building a tricopter but can't decide how long arms to use - 375mm,300mm,480mm or other size and which material to use -wood,carbon fiber tubes, aluminium?
I need a tricopter that could take on board pretty heavy camera (200 gram) + FPV system.
Here are electronics that i think to use, if something isn't right or you would recommend something better,then do it.
Control board KK2.1 - http://www.hobbyking.com/hobbyking/...ntrol_Board_With_6050MPU_And_Atmel_644PA.html
Programming device - http://www.hobbyking.com/hobbyking/...Programming_Device_for_ATMEL_proccessors.html
Motors DT750 - http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=6247&aff=398199
ESC Afro 20Amp - http://hobbyking.com/hobbyking/stor..._Motor_Speed_Controller_SimonK_Firmware_.html
Props : Give me recommendations, which brand props to use, size i need - 11x4,7 and 10x4,7
Battery Turnigy 2200mAh 3S 35C - http://hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=10383
OR
ZIPPY Compact 2700mAh 3S 35C - http://hobbyking.com/hobbyking/store/__21396__ZIPPY_Compact_2700mAh_3S_35C_Lipo_Pack.html
BMS-385DMAX Digital Servo -
http://www.hobbyking.com/hobbyking/...gital_Servo_Metal_Gear_4_2kg_15sec_16_5g.html
Front wheel - http://www.hobbyking.com/hobbyking/store/__8432__Front_Wheel_Steering_Arm_Mount_Set_40mm_5sets_.html
Thanks!
P.S. Sorry for my english..
OR
Thanks!
