ProfessorFate
Have you seen End of the Road RCs FT Mustang with top hatch access?
What about Nerdnics nn P-39 design, tough, huh? good construction ideas there.
Before I even built my 1st power pod for anything I already had a list of special features it just had to have.
This power pod is somewhat specialized in that it is tuned for the FT Mustang and anything else you can make it fit.
A developmental process made this come about.
I started building the standard FT Power Pod but with my choice of materials
There is a 1st pod that's almost finished with built in thrust angles of 4 degrees Right and 4 degrees Down made to fit the Beef Suppo 2217 using a gws 9x5 ep, it uses blind nuts and allen hex head machine screws, because I like to be able to easily remove or switch out motors.
Features:
1: Durable lite-ply 1g/inch, won't get crunched on hard nose-ins, cut big holes in face for cooling
2: Built-in thrust correction 4deg Right & 4deg Down
3: Top hatch batt access, just set it in there, plug in and close hatch, hatch will hold batt with a pin n spring
4: Space problem for ESC solved, 3/4" rails will go on bottom as spacers, ESC goes here and will get plenty of cooling from the front
5: 6-32 firewall blind nuts ( for blind squirrels ), use w/ hex head screws, easy to swap different motors
Add: make a bottom shelf in the fuse that the pod will be supported by, you might even leave out side pinning the fuse then, with it also taped at the top of fuse/pod.
You decide where you want to put internal cross braces to hold the top and sides against any side pulling forces or just to hold it together good, maybe front, back and middle?
Just set it in your FT warbird, tape the top pod sides to the top edge sides of fuse lengthwise
That fiberglass sheeting you see is behind the clear canopy and is a very hard hand grip to handle/remove canopy by.
*** I did start out building a stock FT power pod out of lite ply, but wanting the top access hatch to put bat in pod, like if you have seen End Of The RoadRCs FT Mustang? It just ended up this way, all of these I believe are good ideas, but, this could have been planned better, like one whole panel for the sides extending that extra 3/4" where the spacer will go
Another one with all these ideas, but, just a better layout, would really be the thing to do, and not just stumble on this, this way, but it's discovery as you build, I guess. I'll know better what to build and plan for the next one.
Actual Size here too, I used the WRX formula I made up, I wanted 11"=W, image =32.5"=X, rate "r" to decrease=.3385 so 34% worked just fine
This image was taken close up so you get dimension errors on a side view, that would be reduced on a more distant picture, in natural light 10 feet away
Here's the full size plan of the 40 inch FT Mustang made disguised as a Hawker Hurricane with the new power pod design:
This eliminates a little of the top and nose construction, provided, you build a Hurricane or a different canopy cover.
After you watch The Battle of Britain ( 1969 ) with Michael Caine, Robert Shaw, Kenneth More, Edward Fox (Day of the Jackal) and Laurence Olivier, you may want to build a Hawker Hurricane.
"We have before us an ordeal of the most grievous kind. We have before us many, many long months of struggle and of suffering. You ask, what is our policy? I will say: It is to wage war, by sea, land, and air, with all our might and with all the strength that God can give us; to wage war against a monstrous tyranny never surpassed in the dark, lamentable catalogue of human crime. That is our policy. You ask, what is our aim? I can answer in one word: It is victory, victory at all costs, victory in spite of all terror, victory, however long and hard the road may be." Winston Churchill
Well, then, go see Reach for the Sky, The Story of Douglas Bader ( 1956 ) Kenneth More, another great movie with Hurricanes.
Now the New FT Power Pod IS Planned Better Right Here:
OK so here's an update, I was obsessed with this idea of making a near perfect power pod, and noticed that I was really spending too much time on the hatch cover, so I decided to simplify it (make a flat wood cover and add canopy detail later, make a functional pod 1st) and see where I could also expand the dimensions and design this pod for 2 whole piece side panels, and also for use with canopy making, HEB now has this real tough poster paper ( $0.57 ea ) that would be good for those soft spots on top.
Have no fear about weight, there is so much benefit to this construction that it's worth it, and this lite-ply $10 for one 1/8x12x48" sheet (sold in a 6pack tho) is only 1 gram per square inch, the 1st one above mentioned is about 4oz right now.
I used real strong 1/4" hobby ply for the firewall, this is what makes this work so good, you can drill lots of holes for cooling and even a little bit remaining is strong, I drilled and cut away about half of the 1.75x2x.25" firewall and installed 6-32 Great Planes blind nuts for the motor, these are the ones with the large disc feet, get them at Amazon, 24 pack for $5
The picture with the dimensions pretty much tells you most of the story
Put the battery behind the motor, velcro it down and maybe put a spacer over the battery, tape to the bottom of the hatch
The ESC, glue or secure with zip ties under the battery in the lower compartment
make a hole for the ESC conn and radio pwr feed
make another hole to feed the motor wires to the bottom 3/4" space used for the ESC, the Suppo Beef 1340kv motor has stiff wires so I made a hole in the firewall then straight in-line thru the deck to the ESC
Glue some triangle stock on bottom of the deck where the ESC is, leaving max flat, clear space for the battery above
Some half dividers may be needed to strengthen and hold the pod sides, the outside dimension of the pod remains 2 inches so it should fit a lot of swapables, the Length was increased to help make most canopy schemes work, the Hurricanes and BF 109s all fit forward of the wing trailing edge, Old Crow NA P51 "B" back is even with the TE, Glam Gal NA P51 "D" is long hanging past the TE, FW190 is long past TE just like the Glam Gal Mustang.
By the FT Mustang Plans, this pod will sit right over the top of the wing, that nice straight bottom edge of the pod is supposed to rest on a shelf you build into your plane, easy enough, just 2" by 16" glue bottom or both good
The only thing needed to hold this pod in your FT DTFB low wing warbird is just taping the top edges of the pod to the even top edges of the airplane and it's done, in your construction, try to leave nice long clear areas to tape on both sides of pod for this purpose
I hope I did not leave anything out, I went over and over these numbers checking the fit and to see if it all added up right.
If you think it's too long, after you build it, it's easy enough to trim if you think 16" is too long, I know I put it a little past the bend in the fuse tail, won't matter much tho
There are supposed to be 1/4" dowels used both as stiffeners glued to the bottom of the hatch which is also supposed to have either 3/16" or .25" overhang both sides to match the foam board
You taper the front of these dowels and the insert into tubes made with epoxy and fiberglass, you just bunch it around wax and tape covered dowels, tamp it down nice n smooth, let it cure hard, pull off tape n wax paper and you have things that hold the front of your hatch, also you can just glue a piece of wood under the front of the hatch, you will still want a stiffener for the hatch tho and some kind of spring loaded pin closure at the rear, I am still working on this part
Some kind of small scraps should be glued under the hatch to make it fall centered over the pod, so that secures the hatch 3 ways, front, sideways and sides resting on pod, and pin the back closed against a stationary vertical bulkhead and remember not to close up the pod, you want air to flow thru it,
air should flow clear thru the bottom opening where the ESC is and out the tail
air should flow easily thru the firewall you can make big holes in this stuff but it takes good sharp drill bits
**** Hey!, I made just one minor mistake and found it while cutting out the panels.
No big deal, and if you make one like this, cut out 2 panels 2 7/16" by 16" that's it!
Make a hood 2" long by 2 3/8" and the hatch 16" long by 2 3/8" to overhang the sides at the same height as the foam board, it's 3/16" each side.
Now this is it, the New Lite-Ply power pod actual size, and dimensions checked against the FT Mustang for fit.
This drawing of the FT Mustang is super because it does not have all those @#$@#Q$%!! grid marks on it!
Now I really tried to make use of all available space, so if you find the wing too tight against the pod, just cut out a little bit of the bottom of the pod only where it touches the wing, might only be one or two 16ths.
You should build this, post and let us know how you like it.
Imagine the work this will reduce by already having the top front quarter of an FT Spit/Mustang/Hurricane/Racer/BF 109 already done when you start to build.
Don't mistake it, on the drawing, the side panel is 16" long by 2 9/16" at nose and 2 7/16" aft.
On this one, I don't know if I will put thrust correction, I'll know after I finish the 1st prototype and install in an FT Mustang dressed up as a Hawker Hurricane.
Features:
