Spitfire76
I know I am a bit late to the game in building the Scout XL and I am still not sure that it will fit in my car but started the build anyway. As its a scratch build I used the plans that Sponz developed and kindly shared with the community for the FF2022 dawn patrol challenge. I then used the build video's that FT put together for their SBK and noticed that they had made quite a few changes.
* The front and rear sections of the fuselage are not in the same place. The FT version is much further forward.
* FT Fuse doublers are doubled
* FT Servo doublers are larger, similar to the FT Tutor’s ones
* There is a difference in the bottom front section. The FT one is not spilt at the same point and the cut out section at the front is a different size to take into account the double doublers
* FT power pod has double sides and so is not compatible with Sponz’s 3d printed one but could be adapted by removing part of the side doubles at the front to accommodate.
* FT Turtle desk is split into 3 sections instead of one.
* The top and bottom parts of the wings are joined on the FT version as they use the larger foam board
* On the FT version the front former is changed to accommodate the double doublers.
I am attempting to include these changes to my scratch build.
I am now having trouble to fit the power pod because of the double doublers. I can only assume that the SBK version has a narrower power pod and corresponding reduced firewall size.
